Intel® Desktop Boards
Peer-to-peer support only
11480 Discussions
DG41KR memory support
Community Manager
I have a PC with DG41KR desktop board. I have tried to plug JM1333KLN-4G (240PIN DDR3 1333 Unbuffered DIMM 4GB With 256Mx8 CL9) transcend ram in one of the DIMM slot. But I am getting 3 short beeps and sysyem is not booting. Is this memory not compatiable?
ZAgha
New Contributor II
These are considered high density RAMS & your MB supports only 4-GB.
For a list of tested & compatible RAMS PLS check the link:
http://www.cmtlabs.com/2012/mbSearchResults.asp?sManuf=Intel&sMem=DDR3&sMN=DG41KR&oSubmit=Search CMTL > Search > Tested Motherboard
Don't go beyond 2GB per DIMM
Anything else I'm more than happy to assist
RRamo7
New Contributor III
Hi Vivekt008,
It seems that this ram memory is not compatible, please bear in mind that according to the specs of the motherboard you have, the memory types it supports are DDR3-1066/800, and this RAM memory is 1333 MHz.
