Intel® Desktop Boards
Peer-to-peer support only
11435 Discussions
DG41RQ no enciende
Community Manager
Mi motherboard se encontraba trabajando normalmente y de repente se apago y ya no encendio, en un inicio pense que era la fuente de energia pero esta se encuentra bien, lo raro del caso que solo aparece encendido el LED de energia de reserva de la motherboard.
Community Manager
Hi Amilcar,
Here are our recommendations for this issue:
- Test the system out of the chassis, on a minimal configuration. Remove all memory looking for beep codes.
- Check for fan activity.
- Clear the CMOS battery for 20 minutes and if the system boots into the BIOS, proceed with a BIOS recovery test:
http://www.intel.com/support/motherboards/desktop/sb/cs-022312.htm Desktop Boards — BIOS update instructions
- If the issue persists, check your warranty options to replace the board.
Community Manager
Hi Amilcar,
