Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
DG41TY motherboard not starting
AGupt25
I have an old DG41TY mb. It had stopped working. A repair engg. replaced its Q12 IC (and removed Q36 IC). It started working. After a few days, it again stopped working. This has happened few times. What could be the problem pls. Also what is the actual part no. of Q12 (and Q36). The engg. replaced Q12 with 07N03L transistor. Is it the correct part number?Since I am doing a project on this PC, I dont want to change it for a few more months. Looking forward to hear from someone.
Thanks and Regards,
Arvind Gupta.
AlHill
There is nothing that can be done.
Doc
AGupt25
OK. Thanks for your reply. In that case which motherboard do you recommend for Q6600 processor and 2 X 2GB DDR2 RAM.
Arvind Gupta
AlHill
None. Intel no longer makes desktop boards.
Doc
AGupt25
OK. Kindly recommend another vendor pls.
Arvind Gupta
AlHill
asus, msi, gigabyte, etc. do the research yourself.
doc
