Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
DG43GT Fan issue(s)
I've just built a new desktop PC. It uses the DG43GT motherboard and E2200 CPU. The board shipped with BIOS revision 0019. On initial setup the bios could not detect the CPU fan speed. A update of BIOS to Ver-0024 resolved that issue. However the PC does have a 3-pin Front Panel fan installed. Even with the latest posted BIOS the fan cannot be detected. This is with BIOS hardware monitoring or SpeedFan 4.40 running under Windows 7 32-Bit.
I've tested this with two different fans and have confirmation that the fan is plugged in correctly. During BIOS post I get two instances of a single beep. This is even with the Fan reporting option set to "Disabled".
Anyone else experienced a similar issue >? or is this a known issue that a future BIOS release will resolve.
Highlighted
Community Manager
Nevermind. I re-seated the Glacial Tech connector and remembered to change BIOS fan control to "Detect Next Boot". Once I did that the Front Fan speed was properly detected.
How come you tend to resolve an issue just after you post a question about it ?
Highlighted
Community Manager
you have to organise your thougts for a post, that triggers new thoughts afterwards
