Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
DG43GT Warning: Mointor not found w/ latest bios
Hoping someone has a quick fix for this - using an Asus EN8400GS PCIE video card. It appears there have been multiple bios revision for this issue but the latest one still gives this message on boot then goes ahead and initializes normally.
Anyone?
Highlighted
Community Manager
Re: DG43GT Warning: Mointor not found w/ latest bios
I think it is not motherboard problem.
Valued Contributor I
You mean the Video not supported message for the HUD? I still have to check a hot run temp then I will uninstall.
Highlighted
Community Manager
I also receive same warning message: Monitor not found
Press Enter to continue
I have a gpu GForce 9800 installed and seems to be working ok.
How can I stop receiving this MEssage?
Thanks in advance,
Ayrton
Highlighted
Community Manager
Also happens with NVidia GeForce 9500GT
