Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
DG45ID ACPI Compliant Error on Win 7 Upgrade
I just purchased a BOXDG45ID and clean installed Windows XP Pro SP3. I inserted my Win 7 Upgrade CD, started the install and got the following error:
This computer is not compliant with the Advanced Configuration and Power Interface (ACPI) standard. Windows must be installed onto a computer that supports ACPI. Contact your computer manufacturer for a BIOS update or install Windows on an ACPI-compliant computer.
I just upgraded the bios to version 0177 (I did not try it on the bios version before the upgade).
My computer is a Core 2 Quad Q6600 w/2 gb DDR2 800 mhz ram, a SATA DVD+RW and a SATA 500 GB HD. I have installed the latest chipset drivers. I don't have any other periferials and the only things connected are the kb, mouse and monitor.
I don't know where to go from here. Any help appreciated. Thanks.
Tags (2)
Community Manager
My advice would to fresh install win 7, not upgrade if possible.
Community Manager
Well your post got me thinking and I was able to get Windows 7 installed. Let me explain:
I had tried to install win 7 with my upgrade media by booting to the media and installing on a clean HD - but, the media will tell you that your key is invalid and you needed to boot to a previous version of windows, then install windows 7. So, I installed win xp sp3, and ended up at the point where windows 7 gave me the APCI error (which I can only assume was related to drivers). But, I thought, there has to be a way to do a clean install of windows with upgrade media, especially since the upgrade advisor stated that I should do a custom "clean" install. So, I searched and there is. I found a phenominal article http://www.winsupersite.com/win7/clean_install_upgrade_media.asp here about upgrading Windows 7 through a custom/clean install. All I had to do was boot to the win 7 upgrade disk and select custom install. I'm only assuming that it worked this time because I already had a version of windows installed and activated (where I had not when I tried the first time).
Win 7 is up, running and activated.
Community Manager
I am glad i was of some assistance and you have it sorted now!
