Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
DH55TC/WD My Passport 2TB USB3 HDD/Win8
VSing20
My Intel Board details are as follow
Product Family: Desktop Boards
Product Line: Intel® 5 Series Chipset Boards
Product Name: Intel® Desktop Board DH55TC
PROBLEM: Ever since I have installed Win8 64 bit Operating System on my Desktop my Western Digital My Passport 2 TB USB3 Hard-Drive has stopped working. It actually worked initially but then it went slow and now it gets detected in the task bar at right side bottom on the screen as a notification however in Explorer it doesn't list. Sometimes after a long wait it comes up in explorer as well and shows its content however its dead slow that when I click on any folder inside it makes the window go NOT RESPONDING.
My board has only USB2 however USB3 drives are backward compatible so it should work and it did work initially. I have done several troubleshooting steps and later on Intel's site found out that my board has gone to not supportive list so probably Windows8 drivers are not made for my board.
Anything else works on my board as I have rest all things of USB2.
What can do to fix this problem on my own as Intel will not support this.
Any help on this would be highly appreciated.
Thanks a lot guys.
Best Wishes.
Silvia_L_Intel1
Hello Vishurey,
I know that you were already notified his product has reached its End of Interactive Support so Intel no longer provides support for this product via telephone, chat or e-mail.
However this behavior could be cause because this specific motherboard does not support Windows 8 and there are no drivers available.
  • My recommendation will be to follow normal troubleshooting such as:
  • Test the system out of the chassis, minimal configuration please. (Motherboard, processor, power supply, 1 memory stick and video card)
  • Remove the CMOS battery and leave the system without it for about an hour. Then put it back on and restart the system.
  • Install the latest BIOS version available for your board
If you think the motherboard is defective but it is still under warranty please get in touch with our Warranty Department so they can help you to replace the unit: http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
Regards.
