Hello, i have a DH55tc (i3) with 8GB ram 1600(by default downgrade to 1333) but it shuts down with out a reason, i have check the bios on event log but nothing, also i have checked on the event viewer of windows and still nothing. i change 3 power supply but still the same problem i am running out of ideas could someone help??
Thank you
Hi Mpikou9,
There are some troubleshooting steps I want you to try:
- Disconnect all components from the motherboard including the power supply and battery for 10 minutes.
- Reconnect the system with minimum configuration. This means 1 HDD, 1 Memory Stick and power supply.
- If issue persists, disconnect the memory stick and reconnect it on another memory slot. Repeat this if necessary.
- Try another memory stick.
- make sure memory is running at 1333MHz. If running faster it may cause system stability issues.
- Make sure you test a power supply with enough power output.
In case you have the possibility to test another memory, here you can find compatible memory part numbers for your system:
http://www.intel.com/support/motherboards/desktop/dh55tc/sb/CS-030954.htm http://www.intel.com/support/motherboards/desktop/dh55tc/sb/CS-030954.htm
Kevin M
