Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
DH61AG Bios
DBave
I have the DH61AG motherboard with bios 0045. I would like to update to version 0104. The instructions at the download page are contradictory. See following cut and paste from the download pages.
Case 1.
If your system's current BIOS version is 0039 through 0045:
1. Update to the transition version 0099.
2. Then update to 0104 or later.
Case 2 from release notes for the bios.
If your system's current BIOS is 0039 through 0045:
1. Update to the transition version 0039
Which Method is the right one?
Community Manager
That is probably a typo in the second case since it's unusual to down grade to upgrade. In my experience at least.
Probably, whoever wrote the release notes got confused with this (from the download page):
If your system's current BIOS version is 0037 or earlier:
1. You must first update to version 0039.
2. Then update to the transition version 0099.
3. Finally you can update to 0104 or later.
Community Manager
DBave
The update was succesful from Bios 0045 to 0099 and then to 0104.
Thank You for your help.
EGuit
be carefull if you have XP, after upgrade to BIOS 0099, 0104 or 0105 you could not start
