Intel® Desktop Boards
Peer-to-peer support only
11428 Discussions
DH61BE Not Getting Past BIOS Splash
JLove6
After a bios flash to fix a graphics card problem, which did work, the bios now doesn't get past the Intel splash, Intel board. I can select boot menu but when I select my hard drive it freezes. I can also go into the bios settings and that seems to be functional. Any help would be appreciated.
I did start a thread on tomshardware and I ended up here. Look at thrad for more information: http://www.tomshardware.com/answers/id-2762191/past-bios-splash.html# 16448647 http://www.tomshardware.com/answers/id-2762191/past-bios-splash.html# 16448647
PAnyt
This could well be a BIOS settings issue. Please go into the BIOS setup and try various combinations of boot and HDD settings.
When you installed Windows the first time, do you remember the settings? UEFI or legacy boot? IDE, AHCI or RAID? These settings tell the BIOS how to access your HDD. If they are not the same as they were when you installed Windows, it won't find your data. So try changing the settings one by one until you get it right. There are some 6 combinations to try.
Worst case, you set the boot configuration you want, and install Windows again from a DVD or USB pen drive, delete all the existing partitions on your HDD, and let Windows do its thing. It will create the partitions needed automatically.
Miguel_C_Old
Reinstall the BIOS version 99 using the recovery method. Use the minimum configuration, using motherboard, processor and 1 memory stick.
BE0099.BIO
https://downloadcenter.intel.com/download/22413/BIOS-Update-BEH6110H-86A https://downloadcenter.intel.com/download/22413/BIOS-Update-BEH6110H-86A-
Instructions for Recovery BIOS Update
http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm Desktop Boards — Instructions for Recovery BIOS Update
Miguel
