Everything seems fine, installs the driver and seems to be playing but no sound is heard.
Along with this I realized that the sensor values are not complete Aida, Aida was to say:
Sensor Properties:
W83677HG Sensor Type Winbond / Nuvoton NCT677xF (ISA 290h)
and says:
Sensor Properties:
Sensor Type CPU, HDD, ACPI, PCH, SNB
The voltages (+3.3, +5, and +12) do not appear, as well as some temp (south bridge)
says
Voltage Values:
CPU Core 1.101 V
GPU Core 0.825 V
was to say:
Voltage Values:
CPU Core 1.192 V
+3.3 V 3.264 V
+5 V 4.256 V
+12 V 17,664 V
Camp on +5 V 5.139 V
Southbridge Core 1.056 V
DIMM 2.080 V
GPU Core 1.100 V
Debug Info F 00 23 00 00 00/0 1205 0 0 0
Debug Info T 36 35 40
Debug Info V 95 8A CC CC 85 82 84 (01)
Debug Info I C1 B473
Todo parece estar bien, instala los driver y parece estar reproduciendo el sonido pero no se oye.
Junto a esto me di cuenta que los valores del sensor en el Aida no son completos, el Aida debia decir:
Propiedades del sensor:
Tipo de sensor Winbond W83677HG / Nuvoton NCT677xF (ISA 290h)
y dice:
Tipo de sensor CPU, HDD, ACPI, PCH, SNB
Los voltages (+3.3, +5, y +12) no aparecen, asi como algunas temp (puente sur)
dice:
Valores de voltaje:
Núcleo de la CPU 1.101 V
Núcleo de la GPU 0.825 V
debia decir:
Valores de voltaje:
Núcleo de la CPU 1.192 V
+3.3 V 3.264 V
+5 V 4.256 V
+12 V 17.664 V
Puesta en espera +5 V 5.139 V
Núcleo del Southbridge 1.056 V
DIMM 2.080 V
Núcleo de la GPU 1.100 V
Debug Info F 00 23 00 00 00 / 0 1205 0 0 0
Hi Roly3055,
First, there is an audio issue, so, what is the file you are trying to play? And what is the player being used for this?
Second, about the thermal issue, what is the software you are using to detect that?
No pienso que sea una cuestion de audio, la pc tenia instaldo multiboot con windows xp y 7 64 bits y en los dos sistemas desaparecio el audio completamente (sistema, video, musica, juegos), la reinstalacion no resolvio el problema, despues me di cuenta del problema de los sensores al chequear con Aida 2.85, mas me parece un problema de hardware, algun voltage de la board o algo defectuoso
Have you tried doing BIOS updated? The BIOS version 0109 fixed an issue with the front panel audio.
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Intel%20Desktop%20Board%20DH61BE https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Intel%20Desktop%20Board%20DH61BE
regards,
Yes I update to 0099, 0109 and 0113, and post the solution for boot problem after update to 099
If you continue having the same behavior, feel free to contact your local Intel support group for assistance on replacing your product: http://www.intel.com/p/en_US/support/contactsupport?group=processor http://www.intel.com/p/en_US/support/contactsupport?group=processor
