Intel® Desktop Boards
Peer-to-peer support only
DH61DL question
JGibs3
The DH61DL motherboard says after a certain BIOS revision that it will work with Ivy Bridge processors. All of the ones we have are using the latest BIOS (version 120, the latest from Intel's site). If I put an i3-3220 in one of these motherboards with DDR3-1600 RAM will the board use the memory at the faster speed or will it still limit it to DDR3-1333 speeds?
Community Manager
Hello scarfman4,
Thank you for joining the Desktop Boards community.
The memory should work at the speed of 1600, this based on the fact that the processor and the motherboard support this type of memory. Find the memory types supported here: http://ark.intel.com/products/51855/Intel-Desktop-Board-DH61DL Intel® Desktop Board DH61DL Product Specifications and here: http://ark.intel.com/products/65693/Intel-Core-i3-3220-Processor-3M-Cache-3_30-GHz Intel® Core™ i3-3220 Processor (3M Cache, 3.30 GHz) Product Specifications
If you have more questions, please let us know.
Amy C.
n_scott_pearson
Super User Retired Employee
Actually, unless you made a change in the BIOS configuration, 1600 memory is going to run at 1600 with both the 2nd generation and 3rd generation processors. This is completely independent of the processor generation...
JGibs3
I've put 1600mhz memory in several of these boards with Sandy Bridge processors, and all tests show that the RAM gets reduced down to 1333mhz. Memtest86+ shows it running that speed and so does CPU-Z.
Here's a CPU-Z report log of a DH61DL mobo with an i3-2100 CPU in it and some Hynix DDR3-1600 RAM. It says Memory Frequency is 665mhz, whereas if it runs full speed it should say 800mhz.:
Chipset
Northbridge Intel Sandy Bridge rev. 09
Southbridge Intel H61 rev. B3
Memory Type DDR3
Memory Size 4 GBytes
Channels Dual
Memory Frequency 665.1 MHz (1:5)
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 24
Command Rate (CR) 1T
Host Bridge 0x0100
MCHBAR I/O Base address 0x0FED10000
MCHBAR I/O Size 19456
MCHBAR registers
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Manufacturer (ID) Hyundai Electronics (AD000000000000000000)
Size 2048 MBytes
Max bandwidth PC3-12800 (800 MHz)
Part number HMT325U6CFR8C-PB
Serial number 0132FC82
Manufacturing date Week 30/Year 12
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP no
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC # 1 6.0-6-6-16-22 @ 457 MHz
JEDEC # 2 7.0-7-7-19-26 @ 533 MHz
JEDEC # 3 8.0-8-8-22-30 @ 609 MHz
JEDEC # 4 9.0-9-9-24-33 @ 685 MHz
JEDEC # 5 10.0-10-10-27-37 @ 761 MHz
JEDEC # 6 11.0-11-11-28-39 @ 800 MHz
Looking at the specifications in the previous post it does say "1600 O.C.", so it looks like it should. Guess it will be trial and error.
n_scott_pearson
If you have the memory configured for automatic in the BIOS and it end up not running the highest XMP profile, then the BIOS discovered that the combination of processor, board and memory could not sustain the settings in this profile. In this case, yes, it is going to back off to the default (1333). Any one of these entities may be responsible for this issue, but I rather doubt it is the processor. In this case, I would consider it likely that the same thing will happen with the 3rd generation processor - but it is true that the 3rd generation processors handled 1600 slightly better than 2nd generation, so you never know. Nothing you can do but try it and find out. Worst that will happen is it will stay at the same speed. Either way, this would still represent a performance upgrade...
JGibs3
I went into the BIOS and found the settings to override the memory speed. It shows default already as set to 1600, but it's showing Active still at 1333. I tried going into "Memory Overrides" section and forced the speed to 1600, then rebooted and it still only shows it running at 1333. Memtest86+ also confirms this.
So it is capable of running 1600, but the Sandy Bridge CPU won't let it use it since it doesn't support it.
n_scott_pearson
No, most Sandy Bridge processors supports 1600 just fine. Intel just doesn't officially claim that it supports it (and states that, technically, it is considered overclocking to run memory beyond 1333). I have multiple PCs with Sandy Bridge processors that are running at 1600 without issue.
In your case, if the default is to run at 1600 but you find that it is running at only 1333, this is an indication that the BIOS caught that this system -- this combination of board, processor and DIMMs -- cannot support 1600. You could insert a different set of DIMMs and see it work at 1600 just fine.
JGibs3
We had another system whose motherboard died that had an i3-3220 CPU in it. So I took the processor and tried it on a DH61DL with a DDR3-1600 Hynix memory stick. It shows running at 1600 speed just fine.
At least we have some upgradability on these boards.
