Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
DH61HO BIOS hangs with "EB" when VL800-Q8 USB3 pci-e card installed.
Community Manager
Here is an interesting issue I'm having with a new system build.
System Config:
DH61HO Motherboard
- V0012 BIOS
- i5-3470S CPU
- 16 GB memory
This works fine, however when I add am akasa USB 3.0 PCI express card to the system, BIOS hangs with "EB"... Have to hit reset or cycle power to restart. Ctrl-Alt-Del has no efect! :-(
- Card uses VL800-Q8 chip.
- System behaves the same if card pluged into either 1x Slot, or the 16x
I've tried the card in a older core2 based motherboard, and it works fine.
Thouts?O m1ho
Community Manager
Hello Erik,
We would like to inform you that it is very possible this is a compatibility issue with this device and the motherboard chipset. We recommend testing a different card to narrow the issue.
Test with a higher voltage power supply if possible.
