Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
DH61HO board bios 0813 update using F7 key now its not showing screen
mshar38
i did bios update to DH61HO board from F7 menu using usb drive first i tried 0816 ver. but it has given error that "Capsule Header Invalid" then i tried old 0813 version it completed successfully but after restarting it does not show any screen but all fans are spinning. i have tried removing/changing ram,removing cmos battery and also tried recovery bios by removing jumper and .bio file in usb drive but it is also not giving sign of revival. Is there any way to fix this problem?
n_scott_pearson
Super User Retired Employee
What BIOS were you running previously? Did you read the Release Notes before you attempted this upgrade (there *were* special instructions to follow depending on what version you had installed previously)?
W​hen you attempted BIOS Recovery, what happened? Did you see anything onscreen? Did the flash drive's LED flash (if it had one)?
n_scott_pearson
What I suggest you do is use the BIOS Recovery process to reinstall BIOS 813 and then use the F7 method to install BIOS 816. Read on please...
The BIOS Recovery process is documented here: Intel Desktop Boards Recovery BIOS Update Instructions. Please re-read these instructions carefully before continuing. As well, note - and follow - these additional instructions:
  1. Use USB 2.0 flash drive. Do not use USB 3.0 flash drives.
  2. On a Windows-based PC (NOT a PC running Linux or MACOS), use the standard Windows Format dialog​ to reformat the flash drive using the FAT32 file system (and ONLY the FAT32 file system) and do so with the Quick Format option disabled. If Format app doesn't offer FAT32 as a choice, this means flash drive is too big; get a smaller one.
  3. Copy BIOS file HO0813.BIO onto flash drive. This should be only .BIO file on the flash drive.
  4. Properly eject the flash drive from this PC to ensure no corruption. Do not just yank it out.
  5. Insert flash drive in black USB 2.0 port on the back panel of the board to be updated. Do not use blue USB 3.0 or yellow​ USB Charging ports. Do not use any front panel USB ports.
Hope this helps,
...S​
mshar38
i have already followed these instruction carefully and recovery bios method is also not working
n_scott_pearson
Even if you see nothing on screen, does it access the USB flash drive?
When you power on the system, what does the power LED do? Do you see it flash or is it on solid? If you see flashes, what is the pattern?
mshar38
I'm not sure but led was solid whole the time in all cases
after trying numerous time with every possibility to make work recovery bios method like changing USB port, waiting for long time (~30 minutes), using different USB-drives and using different version of .BIO files
but seeing no response, i have decided to step up the game, downloaded the Binary file of the internet for motherboard and de-soldering the smd BIOS Flash Memory chip using a soldering iron1.jpg
and then reprogramming ic using SBC runnning linux
and then in process of re soldering i have damaged a trace using soldering iron but managed to repair using jumper wire
and then system booted normally as it should be 🙂
mshar38
i guess i can desolder and flash BIOS flash chip using programmer if i can get binary file for this board if that is the last option.
AlHill
Flashing the bios is not an option. I would start looking for another motherboard.
Doc
AlHill
By flashing the bios as you have, using an image from another board, you have created a problem. The other board's branding will be copied. The branding contains Serial Number, UUID, MAC Address, etc., this is a problem as two (or more) boards with same branding will then exist. Those on the net that provide these files are not doing you a favour.
Doc
n_scott_pearson
Al is correct. While you can patch the MAC Address with an appropriate tool, your board is going to have the same Serial Number and UUID as this other person's board.
