Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
DH61SA Bios 0048,0099,0120 Update needed.
JCena3
BE_0120_ReleaseNotes
ftp://ftp.micro-square.nl/Drivers/Mainboard/=OUTDATED=/Intel%20DH61CR/BIOS/0120/BE_0120_ReleaseNotes...
DH61SA.
BEH6110H.86A.0028.2011.0715.1815
current bios is 0028.
i needed a
0048.BIO
0099.BIO
0120. BIO
for earlier than 0048 where can i find the Express Update or iFlash Update the 0048 bios?
can i f7 flash the 0048?and then 0099,0120?
is there anything I should pay attention to?
Please guide me.
The Bios file can found on rebyte and softpedia,But can i trust the third-party websites?
n_scott_pearson
Super User Retired Employee
I have attached a ZIP file that provides these three BIO files.
The Release Notes included a process for upgrading. These involved booting to MSDOS and running iFlash2. Even though I have media set up for booting to MSDOS, I prefer to use BIOS Recovery to do updates like this. Here is the process that I would use:
  1. Follow my standard BIOS Recovery process, which is documented here: https://forums.intel.com/s/question/0D50P00004WTCpdSAH/where-can-i-have-the-dh61br-bios-the-download.... Do this using file BE0048.BIO. After Step 22, where you are exiting from BIOS Setup, once you see the BIOS Splash Screen appear, power off.
  2. On another PC, delete BE0048.BIO file from the USB flash disk.
  3. Copy BE0099.BIO file onto the USB flash disk.
  4. Properly eject the USB flash disk.
  5. Follow my standard BIOS Recovery process, starting at Step 9. Again, after Step 22, once you see the BIOS Splash Screen appear, power off.
  6. On another PC, delete BE0099.BIO file from the USB flash disk.
  7. Copy BE0120.BIO file onto the USB flash disk.
  8. Properly eject the USB flash disk.
  9. Follow my standard BIOS Recovery process, starting at Step 9, but this time you will be going all the way to the end of the process.
If there is anything in these instructions you do not understand or have questions about, stop and respond here.
