Dear All,
By ERROR DH61WW BIOS was updated from Ver 20 to Ver 99 directly.
NO ALERT WAS GIVEN TO update it from Ver 20 to Ver 48 first, then to Ver 99.
Now the motherboard is showing BIOS as DH61BE Ver 99 & getting hanged immediately after boot.
Only F2, F7 Options are available.
Tried to Recover BIOS, but failed.
Please let me know what to do now?
Debashis Basu
Hello Debashis,
If you already try the recovery BIOS once and failed, we recommend clearing the CMOS battery for 20 minutes and try the update again with minimum memory installed:
http://www.intel.com/support/motherboards/desktop/sb/cs-022312.htm http://www.intel.com/support/motherboards/desktop/sb/cs-022312.htm
If the issue still persists check your warranty options to replace the board.
Hello Debashis,
Here exactly the same problem.
From 0020 to 0048 to 0099. (Because of running Windows 8)
In the Bios of 0099 there is Intel Management Engine Firmware 0.0.0.0
From 0099 there is no possible way to start Windows. Upgrading to newer Bios isn't possible, something about the Inter Management Firmware corrupt.
Recovery of 0048 not possible, recovery of 0099 hangs.
Everything tried what's in the link above.
How do I get Intel Management Engine Firmware in the Bios?
I tried all the Bios updates till 0120. No one works...
0099 again does not work, display hangs and I can't click on does not react on Enter...
Hello foxathome,
I have provided the information here. Let's keep working there:
/thread/34282 https://communities.intel.com/thread/34282
Kevin M
