Ver. 99, comes with a new feature called 'secure-boot' or 'efi/uefi'. Disable it, then retry-booting it.....
I too suffered this problem and now out of it.....
hello, same here with your problem.
any one can help in this.
thanks.
Is there any solution to this problem. i also updated my board with BIOS version 0099. but it is now unable to boot my system. i tried BIOS recovery but it also did not worked. help me
same problem here !! tried almost everything like bios recovery etc nothing happens
Im also stuck with .099 and yes uefi its in off and legacy its enabled. No boot. Just hungs. Whats worst is that I cannot upgrade the bios.
This happens with all post 099 bios (BE0109.BIO, BE0111.BIO, BE0113.BIO). I cannot go backwards either.
Try 0111. Go read my post /thread/39008 http://communities.intel.com/thread/39008
Miguel
Here exactly the same problem.
From 0020 to 0048 to 0099. (Because of running Windows 8)
In the Bios of 0099 there is Intel Management Engine Firmware 0.0.0.0
From 0099 there is no possible way to start Windows. Upgrading to newer Bios isn't possible, something about the Inter Management Firmware corrupt.
Recovery of 0048 not possible, recovery of 0099 hangs.
Everything tried what's in the link above.
How do I get Intel Management Engine Firmware in the Bios?
I get the same display as Anibal
I tried all the Bios updates till 0120. No one works...
0099 again does not work, display hangs and I can't click on does not react on Enter...
Please try the steps mentioned above. If issue persists, contact your local support. Here you have the contact information:
http://www.intel.com/p/en_US/support/contactsupport Contact Support
- Un-plug the power,
- remove the CMOS battery
- Remove the BIOS Configuration Jumper for Recovery mode
- Keep 20 ~ 30 minutes
- Recover from USB with Bios ver. 116 (latest) (http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm)
- Updated Successfully
