Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
DH61WW USB Port Issue.
Hello to all,
Few months back i upgraded my system to i5 with Intel® Desktop Board DH61WW. Just few days back i noticed some strange issue with on-board ports. When every i switch between speaker to headphone by changing jacks, My system restarts by itself. Later this started happening with USB port based hardware also. Whenever i insert a pen drive system either shows blue screen and gets restarted or restart without any warning. Later system stopped detecting the pen drives. I am using USB keyboard by Microsoft. To test when i changed the port of keyboard, system restarted without blue screen.
I updated system with latest drivers and windows updates but no help.
Worst thing happened when i updated the BIOS also. On power on i can see power lights on, hard disk working sound, but no display, no hard disk read/write light. please.
On this community there are steps to reset BIOS/CMOS. I will try that. But what about the USB port issue. Any suggestions. Same pen drive is working on other systems without any error.
Niraj
Tags (1)
Highlighted
Community Manager
Hello Niraj,
I understand that you are experiencing boot issues and a short on your USB and analog audio ports.
In regards to your inquires, I recommend you to test your motherboard out of the chassis on a basic configuration and to test with a different power supply as this behavior may be caused by a bad power supply or a short/grounding with the chassis.
Regards.
PV
Community Manager
Hello Victor,
Thank you for your response. After reading few post i have successfully reset the bios. I have formatted my system with latest updated drivers. Now the Pen drive is working fine. Could be a driver issue. I am monitoring system for any such issues. I will contact this forum again if this issue comes again.
Thank you.
Niraj
