Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11360 Discussions
DH61WW not worknig with HD7750
ASama4
hi everyone,
hope you'll understand my problem,my english is poor just a little.
I have a DH61WW for a 2 years now,but I never connected a external graphic card.
last week I bought a PowerColor HD 7750 from a friend which perfect working condition,
and connected to my DH61WW but it gave me no signal (blank-black screen since boot cant do anything).I thought my PCI-E x16 slot remain
dust or something,so i cleaned it,and re-seated the card but the problem is still.
BIOS indicate PCI-E x16 slot is empty (not populated)
i spent countless time with this mess and gave up and connected a HD4850 to my DH61WW.
with a big suprise HD4850 working great on my DH61WW and my HD7750 working perfectly on my friend's PC.
now im kind a lost in this issue and dont know what to do.
I have updated to the latest bios (without any single error )
I have followed the removing CMOS battery solution for 1 hour and re connected (out of chassis without power cables)
HD4850 working perfect on DH61WW which means the board have not any fault.
HD7750 working perfect too on my friend's that means the card have not any fault too.
please help guys.... i saw a member of intel community named sylvia_intel is giving options for many issues cant find him or she
my Spex are:
i3 2100 @ 3.10Ghz
DH61WW
Kingston 4GB (2x2GB's) @ 1333Mhz
450 PSU cameup with the casing (you guys calling it chassis)
Kevin_M_Intel
The recommended power supply for this board with a minimum configuration is 460W. You can check this on the motherboard Technical Product Specification, page 54:
http://downloadmirror.intel.com/19711/eng/DH61WW_TechProdSpec06.pdf http://downloadmirror.intel.com/19711/eng/DH61WW_TechProdSpec06.pdf
Please try using a higher power supply with the video card. Just make sure the video card is properly connected.
Kevin m
ASama4
thank you kevin for your reply.
but i connected 500W PSU too.
but the problem not solved.
JBish3
New Contributor II
ok can you tell me . Which BIOS version you flashed in your board & Which BIOS you have earlier ?
Jiten
ASama4
i think it's 0113 before , and also downgraded to this version and checked my card,no luck.....
JBish3
New Contributor II
Then try 0118 , because i have used the same config earlier . It worked for me. So give it a try with 0118 BIOS.
-Jiten
ASama4
ok i'll,which method can i use for flash? recovery mod or F7 option?
JBish3
New Contributor II
Yeah you can use F7 option just connect flash drive with BIOS file in it . & if u can boot into OS. Then you can just use executable BIOS file.
http://www.intel.com/support/motherboards/desktop/sb/CS-022312.htm Desktop Boards — BIOS Update Instructions
-Jiten
ASama4
Jiten, updated successfully to v0118. but problem still there bro...
ASama4
SLOT 3 PCIE x16 NOT POPULATED
JBish3
New Contributor II
120 is the latest on .. try that .. & one more thing. Can u check Postcode While connecting graphics card ?
ASama4
im sorry,what is the Postcode?
ASama4
ASama4
and a very strange thing happening,i can use my on-board graphics while HD7750 connected.
on-board graphics should be disabled automatically when connected a external card.
i disabled on-board graphics after changing primary video as a PCI-E but the problem is still.
