Intel® Desktop Boards
Peer-to-peer support only
11436 Discussions
DH67BL CPU upgrade and RAM Frequency support
MTart1
I would like to ask if my DH67BL with BIOS 0160 will support a 1600 RAM since I want to intall a new CPU i7 3770 that supports this frequency.
Thanks in advance.
Silvia_L_Intel1
Hello Seagrey, thanks for joining the Intel Community.
Based on the motherboard information, you will be able to use an I7-3770 since it is compatible with it. However, the motherboard supports memory up to 1333 GHz.
Please check the information available in our site http://ark.intel.com/products/50098/Intel-Desktop-Board-DH67BL http://ark.intel.com/products/50098/Intel-Desktop-Board-DH67BL
The use of memory out of specifications will decrease the lifetime of the unit and it could generate damage.
Silvia_L_Intel1
MTart1
Thank you Sylvia for your reply.
Yes I've checked the compatibility informations but I had a doubt about the BIOS since I couldn't find such informations in the release notes.
So the maximum supported RAM frequency for the DH67BL is 1333 even with the latest BIOS and 3rd Generation CPU.
All right and thanks again.
Silvia_L_Intel1
That is correct Seagrey, the memory you should use is 1333 MHz.
