Community
cancel
Showing results for
Search instead for
Did you mean:
RRobe14
DH67BL help
Hello all,
I have a intel DH67BL board and just bought a radeon rx460 graphics card. I get no video. I7 cpu, 16Gb ram, 500 watt ps. Tried everything To fix issue. Tried To flash bios from a 2011 ver. to the only newer one 2012 but when i read the readme doc it's from 2005? Is the card to new for the board? Any help would be great, thank you.
AlHill
I suspect it is a compatibility issue with PCIe 2.0 (your board) and PCIe 3.0 (your card I suspect). Have you contacted the manufacture of the card to determine compatibility with older boards? Do you know the requirements of the card?
In the meantime, here is the techinical specification for your board: http://downloadmirror.intel.com/19485/eng/DH67GD_DH67BL_TechProdSpec04.pdf http://downloadmirror.intel.com/19485/eng/DH67GD_DH67BL_TechProdSpec04.pdf
Look in section 1.4.1 on page 17 for the slot specs.
Doc
RRobe14
Thanks Al, i got the card because the card Is backward compatible. I'll check the specs you provided for the slot. Any idea why the latest bios for the MB shows documentation from 2005 and doesn't even support Windows 7. The boards bios now Is 2011 and intel has a 2012 bios ver. But when i Tried To install it fails.
AlHill
"backwards compatible", as claimed by various manufacturers, is not always correct.
The board does support Windows 7: http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000005640.html Supported Operating Systems for Intel® Desktop Boards
The last bios update was Dec, 4, 2012: http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/intel-desktop-boards-w... Intel® Desktop Board DH67BL
For the bios, you may have to install the versions incrementally.
Doc
RRobe14
Thank you Al for your help, I'm buying a new MB, problem solved.
Community Manager
Hello:
Thank you very much to Al Hill for providing all the details above.
To PeanutsHucko:
I just wanted to confirm the comments posted above, and I hope those details were useful for you.
For this type of scenarios what we recommend to do is a BIOS update to the latest version, if after that, still does not work, then it might be a compatibility issue, and the video card will be too new to work with the board.
Any other inquiry, please do not hesitate in contact us again.
Alberto
