Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11360 Discussions
DH67BL not working after flashing the BIOS. rewrite all was well,all the points are completed, and techer not turn on the screen. The jumper tried to rearrange, does not help
СЕфим
Miguel_C_Old
Hi ifik,
I recommend you to try with the BIOS recovery. It is necessary to remove the BIOS jumper from the motherboard. It is necessary use a second computer, download the .BIO file, try with version 0151 or 0160.
Try with minimum configuration, I mean using motherboard, processor, 1 memory stick of DDR3 1333 and 1600MHz 1.5 or 1.35V, power supply and 1 monitor connected to the motherboard. Unplug hard drives, dedicated graphics card and any other hardware.
Save the .BIO file in the root of the USB drive and plug it to the board using a black USB port from the back panel then, turn the system on and wait until the BIOS update is completed.
https://downloadcenter.intel.com/download/21084/BIOS-Update-BLH6710H-86A https://downloadcenter.intel.com/download/21084/BIOS-Update-BLH6710H-86A-
If problem continues, it will be necessary to replace the board. Intel provides with 3 years of warranty through our http://www.intel.com/content/www/us/en/support/contact-support.html Contact Support
Mike C
СЕфим
Thanks, did not help. when the BIOS chip replaced. topic closed
