I just updated my DH67BL's BIOS from (I think) v146 to the latest which appears to be v160. I updated the BIOS using the F7 method.
After upgrade, at each boot I get a now checksum warning error - which I didn't get before. Apart from this warning nothing else seems amiss (after only a few minutes of use).
I have tried downloading the BIO file again and redoing the upgrade, but it doesn't change anything. I tried clearing the event log in F2 setup. But it keeps reappearing.
I cannot find any other indication here that anyone else has seen this as a problem.
The only change I have noticed with this release is that it respects the settings I made for a primary monitor (the previous version assumed it knew which one the primary monitor was).
Where do I go from here to fix the issue?
Do I need to fix the issue?
Hello Akc42, I would like to let you know that this issue was reported previously and we are still waiting for a new BIOS version in order to fix it.
I would recommend you to roll back to BIOS version 0156. This version is going to eliminate the error you are getting. https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3282&DwnldID=21483&keyword=Intel+Desk... Download Center
If the issue persisted after the installation of the BIOS v0156, please check if the date and time are correct on BIOS. You may also want to try replacing the CMOS battery.
Thanks its fixed the issue.
What I find strange is that version 160 is over a year old. Before posting here I searched the entire site for any reference to any problems with the releases and found none. And version 160 hasn't been pulled. Why not?
Is this just a problem for a small number of people?
I'm glad to know that you got it fixed.
This is not a common behavior, and it has not been reported yet. However I'm going to send this to the corresponding team so they can look at it.
Thanks a lot for your information.
Hi. I also recently upgraded to BIOS version 0160 with the same result: CMOS errors at startup. I will try to downgrade to 0156.
I made some experiments, with BIOS versions 156, 159, 160 and different settings. With BIOS defaults settings, all three versions work OK. However, if I change the setting "IGD Primary Video Port" from AUTO to DVI Digital, versions 159 and 160 gives a checksum warning error. Version 156 works ok.
Not all changes to the default settings throws an error. For example, changing the Num Lock status at boot does not cause any problem.
I guess Intel never fixed this. safe to downgrade from 160 to 156? I may just swap the board and CPU anyway.
I sent the information to the corresponding team, but we haven't received a notification about a new BIOS release for this motherboard.
So it is safe to go back to 156? doesn't look great at this point, it's been a year now.
Tim
You shouldn't have any problem rolling back the BIOS to version 156. Please follow this procedure http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm Desktop Boards — Instructions for Recovery BIOS Update
