As mentioned earlier, by other people, upgrading from 125 and earlier to 151 and later causes problems... About which I did not know.
I updated to the new version, and got a black screen, tried using the programmer to restore my old BIOS version from the dump, but every time I turn on the computer, it is replaced with a new version...
How can I revive the motherboard now?
The latest bios is 0163.
Here is the latest bios:
https://downloadcenter.intel.com/download/28273?product=50101
And, here are instructions for the recovery method:
https://www.intel.com/content/www/us/en/support/articles/000005630/boards-and-kits.html
And, if I were you, I would leave the "programmer" alone, unless you really want to brick your board.
Doc
I tried using recovery, but still a black screen, nothing happened. For the test, I started the computer without RAM, the speaker beeps
"BIOS version 0151 includes support for 3rd Generation Intel® Core™ processors. Due to structural changes in this BIOS version, once a board has been converted to this version or later, it will no longer be possible to downgrade the BIOS to version 0132 or earlier. Attempting a BIOS downgrade to a previous version may fail – the board BIOS will remain at its current version."
So, I need to somehow run the recovery, or get a dump with version 0132 and above
You are not going to get a dump of any bios file. And, why do you need to downgrade? The latest bios supports both 2nd and 3rd gen processors.
Since you are messing with a programmer and are not able to install the latest bios, I can only assume you have trashed something.
This is a discontinued, and un-supported board.
Good luck.
Doc
I used the programmer after I couldn't use the recovery, so I don't think I damaged anything...Apparently, BIOS is trying to install a new version by overwriting the data from my dump
Dear AlHill,
Just seeing this post and my Intel DH67CL running Win10 20H2 (& previously 2004) has been blue screening almost every time it is on for at least an hour. It isn't getting overheated as it's in a skeleton, exposed chassis. Of course, the link you posted was removed and I was wondering if there was another way to get the final BIOS for this system board. Thanks loads!
P. S. My CPU is a i7-2600K, with 8 GB RAM and an Intel SSD.
BIOS Version | BIOS Date: 10/23/18 15:59:18 Ver: 04.06.04 |
Date | 10/23/2018 |
SMBIOS Version | 2.7 |
This is the latest (last) BIOS release and yes, it supports both 2nd and 3rd gen processors.
Hi again Scott! Sorry I haven't replied sooner.
Downloaded your BIOS update but after extracting, it was a .pdf and a .bio file, which I'm not sure what to do with.
How do I go about upgrading my Intel motherboard BIOS with what you sent back in March?
Thanks again *very* much!
Jeff
That depends upon what BIOS you currently have installed. Your first post would seem to indicate that you have BIOS 163, dated 10/23/18. This is the latest.
My question is, what exactly do I do with the .bio file? Don't know what program to use to run/install it.
Thanx again!
The answer is it depends on what BIOS you are running. Tell me what BIOS version you are currently running on.
Yes, the computer needs memory to stop the three beeps.
Did you try recovery with 0163? You did not mention that.
What bios do you currently have installed?
Doc
I had version 0125 installed, I tried to install version 151 and I guess it made some changes. I before tried to recover by version 0132 and 0151, did not work, now I will try to use version 163 for recovery...
