Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
DH67CL Random reboot
dbuen1
I have a DH67CL that is still under warranty. Used this board for about a year on a WHS2011 build with about 6 2TB HDD without any hiccups.
Ditched the WHS2011 and am now using it in a desktop box.
I get random reboots sometimes every 2 minutes, sometimes it will go hours without doing it. I am at my wits end.
Things I have tried replacing
Intel SSD, thought maybe this could be the issue, cloned it to a new intel SSD and RMA'd the old one
Power switch? thought maybe it was a bad power switch.. but nope, still does it on a different switch wired via new header pins
PSU, replaced it with a known good one
CPU, this was replaced with a new one when I switched over to desktop duties
Things I have not replaced
RAM, I've ran it through at least 2 passes of Memtest+
Motherboard
Computer:
Computer Type ACPI x64-based PC
Operating System Microsoft Windows 7 Professional
OS Service Pack [ TRIAL VERSION ]
Internet Explorer 11.0.9600.16476
DirectX DirectX 11.0
Computer Name IO-PC
User Name io
Logon Domain [ TRIAL VERSION ]
Date / Time 2014-01-18 / 22:39
Motherboard:
CPU Type QuadCore Intel Core i5-3570, 3600 MHz (36 x 100)
Motherboard Name Intel Cold Lake DH67CL (3 PCI, 2 PCI-E x1, 1 PCI-E x16, 4 DDR3 DIMM, Audio, Video, Gigabit LAN)
Motherboard Chipset Intel Cougar Point H67, Intel Ivy Bridge
System Memory [ TRIAL VERSION ]
DIMM1: Corsair XMS3 CM3X2G1333C9 2 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (7-7-7-19 @ 518 MHz) (6-6-6-16 @ 444 MHz)
DIMM2: G Skill F3-10666CL7-4GBXH [ TRIAL VERSION ]
DIMM3: Corsair XMS3 CM3X2G1333C9 [ TRIAL VERSION ]
DIMM4: G Skill F3-10666CL7-4GBXH [ TRIAL VERSION ]
BIOS Type AMI (12/04/2012)
Display:
Video Adapter Intel(R) HD Graphics (2112 MB)
3D Accelerator Intel HD Graphics 2500
Monitor Dell P2411H (Digital) [24" LCD] (F8NDP12N0HAU)
Monitor Dell S2740L (HDMI) [27" LCD] (P7D0G3890DDL)
Multimedia:
Audio Adapter Intel Cougar Point HDMI @ Intel Cougar Point PCH - High Definition Audio Controller [B-3]
Audio Adapter Realtek ALC892 @ Intel Cougar Point PCH - High Definition Audio Controller [B-3]
Storage:
IDE Controller Intel(R) Desktop/Workstation/Server Express Chipset SATA AHCI Controller
Disk Drive INTEL SSDSC2BW240A4 (240 GB, SATA-III)
Disk Drive TEAC USB HS-CF Card USB Device
Disk Drive TEAC USB HS-MS Card USB Device
Disk Drive TEAC USB HS-SD Card USB Device
Disk Drive TEAC USB HS-xD/SM USB Device
Disk Drive WDC WD1002FAEX-007BA0 (1000 GB, 7200 RPM, SATA-III)
Optical Drive Optiarc BD-ROM BR-5100S (BD:2x, DVD:8x, CD:24x BD-ROM)
Optical Drive TSSTcorp CDDVDW SH-S223F (DVD+R9:16x, DVD-R9:12x, DVD+RW:22x/8x, DVD-RW:22x/6x, DVD-RAM:12x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW/DVD-RAM)
SMART Hard Disks Status OK
Allan_J_Intel1
I am sorry to hear that have had issues with your motherboard model DH67CL.
I see you have replaced SSD, power supply, power switch and processor and the problem remains.
I assume this has happened after you install Windows 7 on your system.
What about BIOS on your system? Did you get the latest version?
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22273&lang=eng&OSVersion=%0A%09%09%0...
You can try the recovery BIOS, file name BL0160.BIO
See Instructions for BIOS recovery available below:
http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm
Allan.
dbuen1
Allan, I have the latest BIOS.
Processor was changed between the conversion from WHS to Win7(no problems with WHS system)
Allan_J_Intel1
Then the problem is the board itself. I would recommend checking with Intel support at the following URL:
http://www.intel.com/chat www.intel.com/chat
Monday through Friday 7a.m to 5p.m PST and choose Desktop and hit Submit button.
Allan.
