Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
DH67CL - Samsung HD103SJ don't spin up at the blue SATA 6.0 Gb/s connectors
I found the following issue with my new Intel Board DH67CL:
The HDD Samsung HD103SJ don't spin up at the blue SATA 6.0 Gb/s connectors.
Also the BIOS don't recognize the drive.
If the same HDD is connected to the black SATA 3.0 Gb/s connectors it spin up and works without any problems.
Can anyone confirm this issue?
I have also tested a Seagate ST3500320AS and a DVD-Burner at the blue SATA 6.0 Gb/s connectors.
They both becomes recognized by the BIOS and seems to work without any problems.
Now my question is who is the cause of this compatibility issue?
Intel or Samsung?
Perhaps a future BIOS update will solve this issue.
Here my configuration:
Board: Intel DH67CL with current Bios [BLH6710H.86A]
CPU: i7-2600K
Mem: 4GB
Biriem
Tags (1)
Highlighted
New Contributor II
A Western Digital WD10EALS is also running perfect in the blue connector (sata 1) with same Seagate as you in sata 0.
Highlighted
Community Manager
I have a similar problem: I recently installed a new mobo (Gigabyte Z68X-UD3H). When I connected my HD103SJ first (to the SATA3 port) I almost got a heart attack, my drive did not spin up, BIOS did not recognize it and I had no backup of my data of 6 years... After the third or fourth restart, it was recognized by the BIOS and I boot up from my SSD. I checked HDD Sentinel (disk monitor tool) and it showed, that the condition of the drive is 0% (previously was as always 100%) and advised to save my data since the drive has hardware problems. I saved all my data via USB2.0 (took ages) to an external drive.
I was about to return the mobo to the vendor but suddenly I gave a try to hook the drive up to the SATA2 port and it worked perfectly.... I was looking for this problem but I only found a known error of P67 chipsets (B0 stepping) with SATA2 but not with Z68 chipset and SATA3... I bought two brand new HDDs, HD502HJ (SATA2, 500GB) and WD5000AAKX (SATA3, 500GB) and they all work fine with all possible SATA ports... So I came to a conclusion that my new mobo does not "like" my old HDD...
Gabor
Core i5-2500k, GB Z68X-UD3H, 2x2GB Kingston Hyper-X Blu XMP, 1TB HDD, MSI R6870 OC, Zalman 500W.
