I get a pop up box stating "This computer does not meet the minimum requirements for installing the software. Setup will exit"
My system works OK, however one of the system utilities I use reports several of the system drivers are out of date. I tried installing the latest chipset listed for this motherboard and get the error.
OS is Windows 7 Pro version 6.1.7601 SP1
System info:
====== Board ======
Manufacturer Intel Corporation
Product Name DH67CL
Version AAG10212-206
Serial Number BTCL123001W8
BIOS Version BLH6710H.86A.0160.2012.1204.1156
BIOS ROM Size 1024 KB
BIOS Release Date 12/4/2012
====== Processor ======
Manufacturer Intel(R) Corp.
Processor Name Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
Processor Speed 3.1 GHz
Stepping 7
Form Factor Socket LGA1155
Hyper-Threading Technology Status Disabled/Unsupported
====== Memory ======
Error Correction None
Maximum System Memory 32 GB
Memory Slots 4
---- DIMM3 ----
Socket Designation DIMM3
Current Memory Type DDR3
Installed Size 4096 MB
Memory Speed 1333 MHz
---- DIMM1 ----
Socket Designation DIMM1
---- DIMM4 ----
Socket Designation DIMM4
---- DIMM2 ----
Socket Designation DIMM2
====== Onboard Devices ======
# Device Type Video
Device Description Intel(R) HD Graphics Device
Device Status Disabled
# Device Type Ethernet
Device Description Intel(R) 82579V Gigabit Network Device
Device Status Enabled
# Device Type Sound
Device Description Realtek High Definition Audio Device
====== Hard Drive ======
# Model WDC WD1002FAEX-00Y9A0
Max. Transfer Mode UDMA 6 (ATA/133)
Active Transfer Mode UDMA 6 (ATA/133)
S.M.A.R.T. Status Enabled
Size 931 GB
Size 931 GB
# Model WDC WD1002FAEX-00Z3A0
Hello Ned,
Our recommendation for this issue is downloading the driver manually from the following website:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22153&lang=eng&OSVersion=Windows%207... Download Center
Please close any running applications to avoid installation problems during the driver installation.
Thank you. I downloaded per the link provided, then rebooted my system and ran the install and it throws the very same error.
BTW, it is INF_allOS_9.3.0.1026_PV I cannot install (1021 is older version which installs OK)
Hello Ned,
Are you still having issues with the driver after installing the version 1021?
If you do, could you please check under the "Event Viewer" of W7, if there is an error that matches the time while you were trying to installed the driver?
