Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
DH67CLB3 bricked?
AViss
Today i updated my DH67CLB3 bios.
Old bios version:
BLH6710H.86A.0098.2011.0114.1739
For the new bios version i just got the most recent from the intel website: BL0160.BIO (https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22273 Download Center)
I used the f7 methode from a usb stick and everything seemed to be going well, it even showed me a reassuring "bios update has completed succesfully".
Then the computer rebooted and i didn't see anything anymore. No beeps, no signal on the monitor (optical/hard drives seemed to be spinning up normally judging from the sound).
After this i attemped the recovery methode by removing the jumper on the motherboard, still no video (or anything else).
I'm wondering one thing. Is it possible that the bios update actually went fine but that the bios for some reason doesn't want to use the integrated graphics from my i7-2600 anymore?
Is there something i can still try or do i need to replace the motherboard?
Silvia_L_Intel1
Hello Bskbo,
There are many BIOS version between the file 0098 and the latest version 0160. Therefore we recommend customer to do the BIOS update installing some version before going to the more resent one.
At this point we can try to roll back the BIOS to version 0098, please follow up the instructions found here: http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm Desktop Boards — Instructions for Recovery BIOS update
Remove the CMOS battery and leave the system without it for about an hour. Then put it back on and restart the system.
http://www.intel.com/support/motherboards/desktop/sb/CS-028780.htm?wapkw=clear+cmos+battery# datetime http://www.intel.com/support/motherboards/desktop/sb/CS-028780.htm?wapkw=clear+cmos+battery# datetime
If you are able to have your system back at least to the BIOS page, you can try the following sequence until you flash the latest version 0105>0122>0146>0156>0160
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Intel%20Desktop%20Board%20DH67CL https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Intel%20Desktop%20Board%20DH67CL
You can read the information on the release notes and choose which BIOS you would like to install on your motherboard. http://downloadmirror.intel.com/22273/eng/BL_0160_ReleaseNotes.pdf http://downloadmirror.intel.com/22273/eng/BL_0160_ReleaseNotes.pdf
If you continue having the same behavior, feel free to contact your local support group for assistance on replacing your board: http://www.intel.com/p/en_US/support/contactsupport?group=processor http://www.intel.com/p/en_US/support/contactsupport?group=processor
Regards.
Silvia_L_Intel1
Hello Bskbo,
Regards.
MPivn
Hi, does it works? bskbo, did you fix it or replace motherboard? I have same problem as you, I udpated from 105 to 160. I cant roll back BIOS to previous version, BIOS recovery udpate not work, system dont read from CD or USB.. I tried to replace 2nd gen i5 for 3rd gen i3 processor, but it's still the same.
