Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
DH77DF BIOS update to 0100 failed
I just tried to update the BIOS of my DH77DF with the latest version 0100 (date 9/6/2012)
The former version I was using was version 069C. I still used this one, because the 0095 has issue with UEFI booting of Linux.
But.... After the update (using the F7 update option), which itself was 100% succesfull, my computer didn't startup correctly anymore.
When I boot it, I get no screen on my monitor and only hear 2 beeps (pause and 2 more beeps). This indicating there is a problem with the video.
I however am using the onboard/inCPU video of my Intel Core I5 3475S, so it can't be a broken videocard.
I tried clearing all settings by removing the battery, but no succes there...
So I ended up doing a BIOS recovery and am now back to version 069C.
Did anyone else try the 0100 BIOS version for the DH77DF yet ? Anyone have a good idea how I can succesfully update my BIOS ?
The main reason I would like to use it, is because it is stated the XMP memory voltage issue is supposed to be fixed.
Community Manager
In order to ensure compatibility and provide accurate troubleshooting please let us know the part number for memory and power supply you are using.
Community Manager
Hi Dan,
I am using Kingston 8GB DDR3L 1600MHz memory (KHX1600C9D3LK2/8GX Kit) together with a Pico PSU-160-XT power supply.
I have no issues with BIOS version 069C or 0095 (besides the known Linux boot issue), so I do not expect the problem to be with the memory or the PSU....
What I do expect by now, is that there might be an issue with the default settings of the IGD in the BIOS. Could it be this is set to disable onboard/internal video ? I think this because in the release notes there seems to have been problems with this before.
quote out of the release notes of the 0100 BIOS firmware states:
Known Errata:
Recovery downgrade to version before KC0081 will cause IGD disabled in default issue, can only resolved with VGA card inserted
I my case it was not a downgrade, but the description could match my problem. If IGD was disabled and since I don't have an external VGA card, it would make sense to get an error with 2 beeps indicating there is no video.
Is there any way I could check this (without having an external VGA card) ?
Community Manager
I just want to see the response. I've got the exact same setup, except I've got 16GB. I just did a new install of Windows 7 with a 120GB SSD. Everything went spectacular, even loaded all the drivers. I was fixin' to hook up to the net, and download the kajillion updates, when, lo and behold, when I booted up, it hung on the first "Intel on Board... " or something like that blue screen. I managed to boot into the "pick your boot Fxx" screen, and tried, unsuccessfuly, to change the boot order. I thought it was hanging because I had unplugged the external dvd drive. No success. So, I downloaded the 0100 bios update. Tried to install, but it appeared to hang on that first screen again... after restarting, unplugging, undoing the config jumper, unplugging the battery, and trying again, and again, now, I can't even get to the blue screen, nor the "pick your boot Fxx" screen. Nothing now. Can I try something else, or is this an RMA?
Thanks, Mike
Sugar Land, TX
Community Manager
I do wonder if this is the same problem. Because you are not stating you also get 2 beeps, which is a obvious BIOS error. They would come from the motherboard itself....
What you could try, and what made my computer useable again for now, is to recover your BIOS update and restore the former version. For details how to perform this, check http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm
But I would like to keep this thread on the problem on getting the 2 beeps and no screen at all, with the new firmware, and not slide into how to recover firmware, which is well documented int the link above.
Community Manager
Hello Cremersdh,
I also have a DH77DF board and 0100 BIOS is working Ok.
My upgrade process is the following:
  • I downloaded the KC0100.bio file, wich was then copied to a pendrive;
  • I rebooted the system and pressed F7 in the boot process;
  • I selected the pendrive and the bios file;
  • The update had no issues reported and the system rebooted itself;
At least for now everything is working ok.
Maybe your BIOS file got corrupted? The SHA512 of my file is the following:
826fbf7280742ea3862d89f7c1182a18e6eceaec6588471be6101c1f4
3731825075404117d499e5527d4f81849dec86aec6581756d6db2f87
8c8115532dd175d KC0100.bio
IMHO intel should inform a hash for each BIOS file.
This problem seems to be fixed.
Good luck.
PS: Sorry for my english. It is not my native language.
Message was edited by: erc&# 13; &# 13; The hash was cropped. it is now in 3 lines
rmill21
I also updated to 0100 bios. The new GUI bios is very pretty. At first everything seem fine. But had problems. I was watching TV with Hauppauge Colossus TV tuner. I am using Win7 64bit. The TV tuner had some kind of video roll which was very slight. The audio had a hum. This was happening only on one channel. At first I thought something went wrong with my Hauppauge Colossus. Then I ran AID64 system stability test. The test failed within seconds. No over clock everything is stock. I reflash back to 0095 bios. Now Hauppauge Colossus is working just find. The AID64 system stability test runs fine. Something is wrong with this 0100 bios. I will be running 0095 bios until they get 0100 bios fix. Sorry I could not solve your problem. Just wanted you to know someone else was having problems with this bios.
Community Manager
Cremersdh,
I can dig it; I didn't mean to hijack to restore the BIOS. Thanks for the link! I did manage to restore it to 0069 (what came with my motherboard). I had to find an old PCI-e DVI-D video adapter, one with no power requirements, using a DVI-D to HDMI cable, and was finally able to see the BIOS.
After restoring, I changed the Configuration: Video settings. I'm using:
IGD
Primary Video Adapter
IGD Primary Video Port
IGD Secondayr Video Port
No Video Detected Error Beeps
After that, I was able to get back into Windows 7 64bit.
Then I shut down, removed the big PCI-e video adapter, and changed the cable to the onboard DVI-D (blue) port. That's what I'm using now, and all seems well.
I don't want to try to flash the BIOS to the 0100, until I have more issues. So far, none.
Mike
Community Manager
IGD
I also inserted these settings, but didn't try to update to 0100 again yet. I first am awaiting the feedback of Dan_Intel and am also wondering because of the experience of voodoolounge.
Community Manager
erc wrote:
Hello Cremersdh,
Your english is just fine (or as bad as mine, my native language is dutch)
I was wondering if you are using an external VGA card, or the onboard/incpu only ?
Community Manager
I am using the processor GPU (Intel hd 2500) with a DisplayPort cable.
System specs:
CPU: Core i5 - 3550
MB: DH77DF
RAM: Corsair Vengeance LPW
HD: Samsung 160GB/7.200 rpm
PSU: OEM TFX - manufactured by FSP
I may be wrong, but it looks like the new BIOS is not compatible with your RAM. Maybe you could try again with another RAM.
Good luck.
Community Manager
I remembered another thing. The last option In the power section of the BIOS is Flash Update Sleep Delay ( or something like that). The description says it may increase the compatibility with power supplies when enabled. IMHO it is worth a try.
rmill21
My ram works find with 095 bios. If you have to update your ram with a bios change. Intel will have to fit this.
Community Manager
Maybe this applies to the 0100 BIOS, but for the 069, I tried booting with the on-board HDMI output. It froze on the first blue splash screen. No on the bottom right. So I turned the power off, and swithed to the on-board DVI-D output. Booted right up. After I logged in to Windows 7, I unplugged the DVI-D, and plugged in the HDMI. Bam! There's the Windows 7 desktop! I just did a soft reboot, and no dice with the HDMI output.
Community Manager
After checking the information you have provide us, power supply is fine and regarding memory our recommendation is making sure you are using the JEDEC profile DDR3-1333 CL9-9-9 @1.5V or rising the voltage to 1.5V in case that you are using XMP Profile # 1: D3-1600 CL9-9-9 @1.35V.
Remember that the memory controller on the processor will support DDR3-1333/1600MHz rated at 1.5V exclusively. That could be preventing the motherboard to get the BIOS version 0100 working properly.
Community Manager
So Dan: I know we're supposed to do extensive homework before buying memory/motherboard... I've got Kingston HyperX 16GB DDR3-1600 CL10 240-Pin Dimm Kit (2pcs) KHX16C10B1K2/16X. No where does it say "rated at 1.5V exclusively", or even what clock/voltage it's good for. So, how do I find out about the JEDEC profile or XMP Profile # 1?
Community Manager
I took all reactions above into consideration and updated my BIOS again today.
This time it was succesfull !!!
I executed the following steps before updating:
- downloaded the BIOS 0100 version again to make sure it was not corrupted and put in on a USB-stick
- put my current BIOS settings back to the default settings
- changed the IGD so it would always be enabled and would be the primary adapter using DVI-D
- changed the Flash Update Sleep Delay option for better PSU compatibility
- updated my BIOS by using F7
I now am finally using the 0100 BIOS version. With the all new graphical layout !
And for those who had the same problem with the former 095 version, even Linux is booting again (unfortunately still without UEFI support)
So my issues seems fixed. Thanks all for your valuable inputs !
Community Manager
Hi Mike,
Since the memory you are using is designed to work from factory at 1600MHz 1.5V, there is no need to use a specific profile. XMP profiles are recommended only when using memory with higher frequencies and voltages.
LHatt
I encountered the same issue when I tried to update to BIOS 0100.
I had Win7 x67 installed and all the drivers were recognized, but when I ran the BIOS update exe from Windows, it never recovered from the reboot. I've tried recovery from USB, but I can't see anything on the HDMI, or DVI-D connector. I even tried plugging in another PCIe graphic card with VGA and no video is coning out, so I have no way to restore the BIOS to the older version
Any suggestions?
Larry
LHatt
Okay, after a lot of trial and error, I found out how to bring my DH77DF back from the dead - and we all know that mostly dead is slightly alive .
The problem appears to be that BIOS KC0100.BIO cannot upgrade KC0069C.BIO directly, you must first upgrade to 0095, then upgrade to 0100. I was also confused by the fact that the BIOS updater was apparently not working, but then I found out that there were some hidden files and folders on my USB-FAT16 thumb drive.
In order to recover from my blocked situation, I unplugged the power cable, unplugged the CMOS battery, removed the BIOS jumper and let the system sit idle for 10 minutes while I reformatted the UDB-FAT16 flash drive and copied only KC0069C.BIO to it.
Get all BIOS versions here (just download the *.BIO versions)
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22DH77DF%22 http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22DH77DF%22
Then I inserted the newly formated flash into the yellow, high-power USB port just above the 1394/firewire port.
Then I plugged the CMOS battery back in, plugged the power cable in, and left the BIOS jump off.
Then powered on the system. For a few seconds, I didn't think it was working, but if you wait about 15 seconds or so, you'll see the front panel LED start to blink which tells you that the BIOS is updating.
If you can see the screen, just follow the instructions.
If you can't see the screen, just give the update 10 minutes to complete, then power down, unplug the power cable, remove the USB stick, replace the BIOS jumper, and wait a couple minutes.
Then plug the power back in, and power up. You should be able to see the BIOS screen this time (at least it worked for me).
From there, I repeated the above steps with KC0095.BIO and KC0100.BIO. Be sure to remove the older BIO file from the USB disk each time.
Now I have a fully functional motherboard, with 0100 BIOS running Win7 X64
Good luck!
