Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11460 Discussions
DH77DF Desktop Board - any loose DVII/HDMI soldered connectors?
MWein7
Four boards were just reported to have loose connectors upon opening the factory-sealed individual retail boxes. Date Code is June 2013.
These connectors are soldered to the board in four places. No other loose pieces were reported.
I was wondering if anyone else has had this problem recently.
Someone posted a similar problem with Date Code Sept 2012 (on You Tube of all places).
I'm trying to figure out if this is due to a factory defect (doubtful), damage in transit, handling after the boxes were opened, or ???.
Any history would be appreciated.
Thanks in advance.
Kevin_M_Intel
Hello MWDigital,
In the case that the motherboard are not working properly or came with loose parts, I recommend you contacting your local Technical support department so we can help you out with the replacement of the units.
