Intel® Desktop Boards
Peer-to-peer support only
11475 Discussions
DH77DF unable to boot
Community Manager
Hello!
I'm working on building a system with the following components:
Intel i7-3770S Ivy Bridge 3.1GHz (3,9 GHz Turbo) LGA 1155 65W Processor
Intel DH77DF Motherboard
Kingston HyperX 8GB (2 x 4GB) 240-Pin DDR3 SDRAM 1600 (PC3 12800) (model KHX1600C9D3K2/8GX) RAM
Intel 520 Series Cherryville 2.5" 180GB SATA 3 SSD
Samsung Slim DVD Optical Drive
Antec ISK 300-150 Black Mini-ITX Case
The system is in a minimal configuration with the power supply connected and the processor installed. I have no RAM installed since I'm hoping it will at least beep to give a memory error, but I haven't had it beep yet. When powered on, the CPU fan starts, but there is no video (I've tried both DVI and HDMI cables) and no sounds.
The manufacturing date per the motherboard box was 27MAY2012. I think the BIOS may be out of date for the processor and/or memory. I've cleared the CMOS and tried flashing several times with the 69, 95, and 104 BIOS release using the recovery process (USB stick drive with .BIO image, BIOS jumper removed). Each time the system eventually powers down on its own, but I'm still not convinced the flash was successful.
Here are my questions:
1) Does the RAM need to be installed when flashing the BIOS via the USB stick drive?
2) Does the USB stick need to be formatted in any particular format (e.g. FAT32)?
3) Any other ideas on why the system won't boot or steps I could try to debug?
Please let me know if any additional details would help.
Thanks in advance!
Community Manager
I've tried flashing with a single memory stick in the first DIMM slot (following the integration guide instructions for placement of a single stick) and the results are similar except the system seems to no longer power itself down.
Can any USB port be used? I have an 8GB USB drive and I've been using the yellow high current USB 2.0 ports.
Some additional info.:
Model: DH77DF
Serial: BTDF22102BKA
AA: Q40293-300
Thanks!
Community Manager
According to:
http://processormatch.intel.com/CompDB/SearchResult.aspx?BoardName=dh77df http://processormatch.intel.com/CompDB/SearchResult.aspx?BoardName=dh77df
the board is compatible with the 3770S processor using BIOS 69.
And according to:
http://www.intel.com/support/motherboards/desktop/dh77df/sb/CS-033192.htm http://www.intel.com/support/motherboards/desktop/dh77df/sb/CS-033192.htm
KINGSTONKHX1600C9D32 GB1600
the RAM is compatible.. so I'm stumped. Both the 12-pin and 4-pin power supply cables are connected, BIOS jumper is correct, I've double checked that the CPU is installed correctly with pin 1 oriented as it should be, etc.. not sure what else I can try. No video, no beeps from the board. Guess I'll give Intel support a call tomorrow..
Community Manager
As a follow up, I ended up RMA'ing the board. The new board worked the first try.
