Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
DH77EB BIOS 0101 Error "Current BIOS is an unsupported legacy BIOS".
tstob
Board has BIOS 0100. When I try to update with EBH7710H.86A.0101.EB.EXE I get "Current BIOS is an unsupported legacy BIOS".
I would like the frame rate fix.
DMI BIOS
vendor Intel Corp.
version EBH7710H.86A.0100.2013.0312.1351
date 03/12/2013
ROM size 8192 KB
Jose_H_Intel1
In this case you may want to try clearing the CMOS by removing the battery from the motherboard for 20 minutes with no power connected to it.
Then you may attempt a different BIOS update method, such as F7 or Recovery using the .BIO file. Instructions in the link below:
BIOS update instructions
http://www.intel.com/support/motherboards/desktop/sb/cs-022312.htm http://www.intel.com/support/motherboards/desktop/sb/cs-022312.htm
