Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11463 Discussions
DH77EB - Unable to get RAID to work
CCoom
I have installed Windows 7 Home Premium with 2 500G hard drives and wanted to setup a RAID 1 configuration. When I change the option in the BIOS to RAID, the OS does not boot and it goes straight back to POST. I have uninstalled RST and reinstalled with no success. Here is some of my system information:
Board
Manufacturer Intel Corporation
Product Name DH77EB
Version AAG39073-305
Serial Number BQEB33300089
BIOS Version EBH7710H.86A.0101.2013.0516.1649
BIOS ROM Size 8192 KB
BIOS Release Date 5/16/2013
Processor
Manufacturer Intel(R) Corporation
Processor Name Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
Processor Speed 3.4 GHz
Stepping 9
Form Factor Socket LGA1155
Hyper-Threading Technology Status Disabled/Unsupported
Memory
Error Correction None
Maximum System Memory 32 GB
Memory Slots 4
Socket Designation DIMM3
Current Memory Type DDR3
Installed Size 4096 MB
Memory Speed 1333 MHz
Socket Designation DIMM1
Socket Designation DIMM4
Socket Designation DIMM2
Onboard Devices
Device Type Video
Device Description Intel(R) HD Graphics Device
Device Status Enabled
Device Type Ethernet
Device Description Intel(R) 82579V Gigabit Network Device
Device Type Sound
Device Description Realtek High Definition Audio Device
Hard Drive
Model ST3500413AS
Max. Transfer Mode UDMA 6 (ATA/133)
Active Transfer Mode UDMA 5 (ATA/100)
S.M.A.R.T. Status Enabled
Size 465 GB
Model WDC WD5002AALX-00J37A0
What do I need to do in order to get the RAID function working?
Silvia_L_Intel1
Hello Tuvixcrc, this behavior could be related to the SATA mode chosen when the operating system was installed on your computer.
The SATA mode on BIOS have 3 settings, IDE, AHCI and RAID. If the OS was installed on AHCI mode, and then you changed it to RAID, the OS is not going to find the appropriate path in order to boot up.
In order to find out if that is the issue you would need to access BIOS and change the SATA mode to AHCI or IDE and try to boot to Windows.
If you change the SATA mode to RAID, you would need to change it before the installation of the operating system.
At this point, if you change the setting, you would need to do a clean installation of the OS.
CCoom
Dear sylvia_intel:
Thank you so much! I did install the OS as AHCI and did not change it in the BIOS to RAID before installing the OS.
I really appreciate your answer. This was my first time doing a complete build on my own and did not know to access the BIOS and change this setting before installing the OS.
Thank you again!
tuvixcrc
