Hello, I have a Corsair Hydro H60 on my i7-3770 and the pump is plugged into the CPU fan header operating @ 4500RPM, the 120mm fan is connected to the AUX fan header and is set to an Inlet in the BIOS. The problem is that the fan is rated for 2000RPM but is currently operating at 800RPM leaving a lot to be desired.
I've tried manually changing the speeds and nothing seems to change. Even setting the automatic slider to "Cool" doesn't stick if I save and exit.
