Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
DH77KC / HD4000 / disable one graphics head?
Does anyone know if it's possible to disable one graphics head (either HDMI or DisplayPort, I don't care) of the three on an i7 3770 running on DH77KC? I've hunted through the BIOS settings and can't find anything.
Background is that I'm using SoftXpand to run simulataneous workstations and in order to enable hardware acceleration it needs all heads on the graphics cards allocated to the same workstations, but only supports two heads not three.
Thanks for any advice.
Highlighted
Community Manager
The configuration you are looking to arrange is not supported. You can try connecting just the HDMI or just the Display port along with the graphics for the i7-3770.
