Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11451 Discussions
DH77KC Mobo and PCI-e 2.0 x4 SSD
Community Manager
I am planning overhaul my PC soon and am planning to buy a PCI-e 2.0 x4 SSD. In terms of all other factors I determined that the DH77KC board was the best for me. However, from researching I discovered 2 potential problems.
1. The motherboard/BIOS needs to support booting from PCI-e
2. There is a problem with many motherboards in which PCI-e SSD cannot be used while the SATA controller is set to RAID mode because there is not enough memory in the ROM.
I am planning to have the PCI-e SSD as my boot drive and have a normal hard drive RAID array as my partition for games so I would like to use the SSD and RAID at the same time.
So what I would like to know (if anybody knows) is whether:
A. The DH77KC supports booting from PCI-e
and
B. Whether the DH77KC's on-board SATA controller will be able to support RAID mode and the PCI-e SSD at the same time
Even if you are not sure but have a good guess at either question, any help is appreciated.
Thank you.
