Intel® Desktop Boards
Peer-to-peer support only
11480 Discussions
DH77KC & Lucid Virtu
Community Manager
Hello all,
Can anyone tell me which version of Virtu this motherboard is licensed to use?
Thank you,
Marty.
Community Manager
In the BIOS release notes for your motherboard it says:
  • Updated Lucid* key.
But for my, and some other motherboards they wrote:
  • Updated Lucid Virtu* MVP key.
So i am not sure.. i guess they added MVP key for your motherboard too, but they forgot to write MVP.
Because Intel has not released any oem Virtu MVP software for Intel motherboards, the key that they added to BIOS is useless. You will have to wait some more i guess.
Community Manager
I saw that a few days ago and updated the bios, it's all very ambiguous.
I wish an Intel employee would give me an answer.
By the way, Windows 8 versions of 'MVP' are out there if you search.
Community Manager
No one at Intel can answer this?
Community Manager
Got fed up with waiting, Lucid MVP works. There is a version out there for Windows 8, not to hard to find.
Community Manager
Where did you download it, from the official lucid website?
Community Manager
BIOS version 0060 makes Lucid Virtu MVP 2.1.220 & 2.1.221 work.
http://www.lucidlogix.com/driverdownloads-mvp.shtml lucidlogix with GPU Solution
Community Manager
It worked before the Bios update...
apale2
and this activated the full version not evaluation version?
Community Manager
apale2
yes I seen it about 10 min ago .... This is good hopefully it works . I won't be off work for a few more hours but if anyone can confirm this is working that would be great!
Community Manager
But i noticed the version number is odd, because on Lucid site there is only 2.1 but the Intel version is 2.0.108.18815 so it seems to be a older one.
apale2
YEs I noticed that too actually I don't think their should be a major difference between the two maybe some more games are supported
apale2
Hey quick question ..For lucid mvp are you suppose to set the integrated graphic device in the bios to always enable or enable if primary?
Community Manager
Intel has pulled MVP from downloads center for whatever reason.
Anyone can upload it somewhere?
ln31
They still have the previous version I see it there a few pages in, but it's called Lucid Virtu Universal, dated 12/15/2011 v2.0.108.18815
I installed it the other day to play with it, at first I also did notice it said evaluation, I researched that on google and saw lots on that, and some suggestion how to fix that and/or it wasn't really an evaluation version, anyway after rebooting or something it didn't say evaluation anymore.
Anyway I didn't like it or think I needed or wanted it, and so I uninstalled it.
Community Manager
The MVP removed is the same on the LucidLogix download part http://www.lucidlogix.com/driverdownloads-mvp.shtml lucidlogix with GPU Solution
Only this version 2.1.221 runs on my MB (DZ77 series with HD4000 and discrete nvidia) and license activated.
ln31
Hey thanks for that link and info fyr !
I've saved the setup file it in my Lucid folder now in case I want to play with it again, since I have the same setup as you then this time I know it's the right one to test with. Thanks
