Intel® Desktop Boards
Peer-to-peer support only
DH77KC bord error
Community Manager
I Have installed a DH77KC with a I5 3550K and Corsair memory, everything was running fine but after one week when starting 3 beep and computer restarts, anyone that know what 3 beep means..
Regards Henrik
Community Manager
Hello Henrik,
To answer your question, three beep codes stands for a memory problem. Here are our recommendations:
-Test the system with minimum memory installed. Test each memory module individually on each memory slot one at the time to narrow the issue properly.
-Ensure the memory you are using is rated at DDR3-1333/1600 1.5V
carloshgh1983
A mí es porque no reconoce los 3ra generación y no funciona el dual Channel
AlHill
@carloshgh1983 This is a 9 year old thread.   Start a new thread for yourself and explain your problem clearly.
