Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
DH77KC optical drive incompatibility
BFlor9
Tried for a couple hours on the weekend to get a Pioneer BDC-202 optical drive to work off of a DH77KC. When connected to SATA 0 or 1 it is not detected at all, when connected to 2, 3, or 4, it is detected but the tray hesitates when opening/closing, takes an eternity to just catalog a disk, and constantly makes a grinding noise even with no disk inserted.
The same drive was then tested in several other PCs, including a Q75 based HP, and worked perfectly.
Any thoughts at all?
Silvia_L_Intel1
Hello ICSSD,
SATA 0 and 1 are what we called SATA 3 (6.0 Gb/s), therefore it could be a compatibility issue between these ports and the optical drive.
Also, you may want to check if your motherboard has the latest BIOS installed. If not, please let me know which is the BIOS version that you have in order to let you know which one you can flash on your system.
Regards.
BFlor9
Yes, I figured that the 6G ports dont like the drive at all, hence undetected, but the behavior when connected to the 3G ports is far more puzzling. Its almost as if the drive is constantly being interrupted. Normally I would blame the drive but as I said it works perfectly on several other platforms (the closest of which is the Q75 I tried it on).
BIOS on the DH77KC is absolute latest as of this writing (0110).
Silvia_L_Intel1
The issue could be related to compatibility, so I recommend you to try other optical drive.
Regards.
