Intel® Desktop Boards
Peer-to-peer support only
11477 Discussions
DH87MC, 7.81 GB of RAM usable out of 8 GB
DKiki
Hello!
I have a total of 8 GB RAM installed and Windows 7 Professional 64-bit reports 7.81 GB usable in Control Panel, System.
In the same system I also have Debian Linux installed and I am seeing the same amount of RAM in htop.
Since I have disabled the integrated graphics of the CPU (in the BIOS settings), I was wondering what is this 0.2 GB of RAM reserved for. Is this normal or am I doing something wrong?
PWert
Valued Contributor I
Demetris - Did you check this link? http://support.microsoft.com/kb/978610 http://support.microsoft.com/kb/978610 . Regards. Peter
Kevin_M_Intel
Hello demetris,
Note that this amount (200 MHz) of RAM memory is dedicated for other internal components such us BIOS, OS, and more devices.
IPoga
Hey Demetris,
I actually have the same issue as you and I consider all previous answers either wrong or a blatant lack of knowledge.
In any circumstance, the available memory should not be affected if the internal GPU is disabled, and other than this, there seems to be no other resource that would reserve that amount of memory [MB not MHz]
Setting different values of memory reserved for onboard GPU seems to not affect the available memory [strange !]. If this doesn't affect, then something else does and somebody should give a better answer.
Also, setting of voltages and XMP profiles is faulty and barely functional, at best.
The BIOS/MB failes to properly read XMP values, and even though it is displaying 1600 in the calculated value [performance] it ends up. Manually setting the frequency to 1600MHz works but voltage doesn't, still keeps 1.5 and for the memory I am using I require 1.65.
I had another board, a Gigabyte with a Z87 chipset, which did not have those kinds of issues. [available memory and XMP]
I sincerely hope it's only a matter of BIOS, which can be solved, otherwise I am dissapointed in the product that Intel put out, compared to the quality they put out before.
