Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
DH87MC Fast Boot breaks W8.1RTM Boot
FHaje
Hy,
I'm using german W8.1 RTM, 1 Samsung SSD 840PRO, Sata configured as RAID for further use with 2 additional WD drives, i7-4770, newest drivers from downloadcenter.
Reproducable: Install W8.1 from USB stick 64 bit gpt-drive, uefi boot. Reboot, Change BIOS to Fast Boot enabled, W8.1 comes with automatic repair preparation, endless. Reset, Change Bios Fast Boot disabled again. ... no boot device availiable....
I tried refresh System, rebuildbcd , chkdsk, many more from within the 8.1 recovery Options (Booting from stick) nothing helped. The data seems to be fine on the SSD, but no boot possible.
Any help is appreciated
Fritz
FHaje
Hy,
using even W8 64 Prof with another HD had the same effect. Changing BIOS to Fast Boot enabled W8 came up with automatic repair preparation. The only difference was, changing the Fast Boot back, W8 booted again, W8.1 not.
But there should be no automatic repair preparation when changing to Fastboot.
Fritz
Silvia_L_Intel1
FritzHajek, when you enable FAST boot, it automatically disabled some Boot ROM options. So when you restarted the system, the Master Boot record (MBR) detects an error on your system, therefore you are getting that message.
Since you already tried another operating system, I would recommend you to try a BIOS update to the next version.
If the issue persists, you can try replacing the motherboard.
