Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
DH87MC PXE error with DHCP
JAnde1
Just got a hold of the brand new DH87MC motherboard. Using with a new intel i7 CPU of the 4th generation.
Thought I'd try to install an image I have with the H77 chip, to see if it works at all.
But I cant get my WDS to even start installing on the onboard LAN chip.
It boots up, says "starting installation" but then after a few minutes it comes back with an error of: WDSclient: an error occured while trying to obtain an IP address from the DHCP server. Please check to ensure that there is an operational DHCP server on this network segment"
Now, doing the same procedure but with an intel gigabit GT desktop LAN adapter it works without fault.
I've checked my DHCP server, lots of free IP adresses.
So I then thought, maybe it's just one board that is defect or so.
But I get the exact same issue with the next identical computer I built.
There is no BIOS update at all. Even tried flashing to the current BIOS version, no change.
I'm using a Windows Deployment Server 2012 on a virtual system. The bootfiles are from a windows 2012 server (x64), and a windows 8 x86 installmedia.
Both boot images creates the same error.
Something's wrong with the onboard LAN, no idea what.
BIOS release notes says: v1403 PXE 2.1 Build 091
Karthi_J_Intel
Hi Johan,
Please try adding network driver to the RIS installation.
Below is the guide to setup network driver for RIS installation
http://www.intel.com/support/network/sb/CS-028856.htm?wapkw=%22intel++gigabit+ct+desktop+adapter%22+... Network Connectivity — How do I setup Intel� Gigabit Network Connection drivers for RIS installation?
Below is the link to download drivers
http://www.intel.com/support/network/sb/CS-006120.htm Network Connectivity — Drivers and software for Intel� PRO/1000 Gigabit Server Adapters
Regards...Karthi
JAnde1
Hi.
Thank you for your response.
I've now added the driver packages in the link you added, also the driver files from the download page of the actual drivers for the motherboard. the x64 bit boot now works.
However the x86 architecture to the x86 bootfile, with all the added x86 version driver still gives me the same error.
Any tips?
Karthi_J_Intel
Johan,
Glad to hear that x64 boot works. Try with the driver (file name: PROWin32.exe) in link below for x86.
https://downloadcenter.intel.com/detail_desc.aspx?DwnldID=21642 https://downloadcenter.intel.com/detail_desc.aspx?DwnldID=21642.
JAnde1
