Intel® Desktop Boards
Peer-to-peer support only
DH87MC TPM-Modul
CSeid
what TPM-Modul is supported by the DH87MC? The board has a 20-PIN TPM-Header on board, but there is no other information is the manual. Is there an Intel Part-Number?
Christian
kwars
i have an intel DH87RL board, which also has an 20-pin tpm header... i bought the asus tpm module (ASUS 90-C1B0AU-00XBN0VZ) http://geizhals.at/asus-tpm-modul-a270218.html http://geizhals.at/asus-tpm-modul-a270218.html which works fine here with windows 8.1 and bitlocker... i'm pretty sure it would also work with your board...
KT2
Hi all,
I am looking to add a TPM for my DH87RL motherboard too.. for Windows 8.1 and Bitlocker.. Does "any" TPM module work? or is there a list of specific TPM tech.. I am worried about whether the mother board bios will support TPM.. Any directions to links I can use to buy TPM in US of A ( currently I see a couple of links on Amazon... and I am not sure if it will work with my motherboard or not ) ?
KTR
kwars
intel and asus boards seem to have the same connector, gigabyte uses different pin layout, so gigabyte tpm modules do not work directly
this one is pretty sure the module i am using: http://www.amazon.com/Asus-Accessory-TPM-FW3-19-BitLocker/dp/B0085E4WQQ/ref=sr_1_1?ie=UTF8&qid=14004... Amazon.com: Asus Accessory TPM FW3.19 TPM Module BitLocker FW3.19 for Asus MB Retail: Computers & Accessories
...do not forget to enable the tpm in bios after installing it...
