I have a DH87RL board that I have sat on a test jig. Initially it started fine (multiple times) and posted to boot screen.
As is my habit I downloaded the latest BIOS to flash prior to installing into a chassis. After flashing ( 0322 from memory) the bare board no longer boots and just give a 3 beeps (memory issue I believe). The memory is DDR3 PC3-12800 • 9-9-9-24 • Unbuffered • NON-ECC • DDR3-1600 • 1.5V • 512Meg x 64 (http://www.crucial.com/store/partspecs.aspx?imodule=BLS4G3D1609DS1S00 http://www.crucial.com/store/partspecs.aspx?imodule=BLS4G3D1609DS1S00) 2 sticks in slots in DIMM slot 1 and 2.
I have tried other memory with no success, as the board worked fine with memory prior to BIOS update and seeing that that there are many BIOS related issues on the DH87RL I wondered if the BIOS update could be the cause ?
No amount of battery removing or jumper changing is fixing the problem, I am trying to recover back to an earlier BIOS from USB stick but the board is not seemingly going past the 3 beeps.
Is there another way of forcing the BIOS back ?
Thanks for any help...
Hi Paul,
I recommend you doing some steps first:
- Take the board outside of the chassis and disconnect all components from it.
- While having the board in a non-conduct surface, remove the Bios Jumper and also the battery.
- Leave the board in this state for about 20-30 minutes.
- Reconnect the system with the minimum configuration. I mean 1 memory stick, 1 HDD etc…
- Once you have minimum configuration, proceed with the Bios recovery options available here:
http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm?wapkw=(Bios+recovery) http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm?wapkw=(Bios+recovery)
In the case that the issue persists, I recommend you contacting the place of purchase for a possible replacement of the board due to the bios problem or you can contact your Intel® local support.
Thanks for the reply Kevin. tried what you suggested but no joy.
Hi Paul Morris,
In this case, I recommend you contacting your local support for a possible replacement of the unit. You can check the following link:
http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
