Intel® Desktop Boards
Peer-to-peer support only
11477 Discussions
DH87RL Rapid Storage Accelerated Volume Selection
DEdwa3
DH87RL with BIOS version 0322 UEFI
Rapid Storage 12.8.0.1016
Rapid Start 3.0.0.1053
Windows 8.1 x64
Primary HDD
Secondary HDD
mSATA SSD
I installed Windows 8.1 followed by Rapid Storage and Rapid Start. SATA operation mode is RAID. With Rapid Start setup and installed I moved to configure my cache drive. When I went to accelerate Rapid Storage would recognize all three volumes but only allow me to accelerate the non-system secondary drive. Even though Rapid Storage correctly showed my primary HDD as a system volume I was unable to select it. At this point I had a Rapid Start partition on the SSD and the system volume. I made no changes to the system volume when configuring Rapid Start. Next I decided to unplug my secondary HDD while powered down. When I powered up again the system was unable to locate a boot volume. The secondary HDD certainly wasn't a boot volume. Now I am unable to boot again with my Windows installation disk as the system BSODs before getting to the main install screen. If I look in the Visual BIOS there are now SEVERAL entries for the same boot volumes for UEFI. They seem to multiply based on the number of disks I have connected. None of them work. The system will no longer boot. I am going to remove the CMOS battery again for a bit to see if I can boot after that. There appears to be issues with the BIOS and UEFI boot. Any help would be greatly appreciated.
DEdwa3
All of my other posts on these similar issues:
/thread/47072 https://communities.intel.com/thread/47072
Rapid Start vs Rapid Storage vs Rapid Response, etc.
/thread/47005 https://communities.intel.com/thread/47005
Rapid Start vs Rapid Response vs Rapid Storage
/thread/46996 https://communities.intel.com/thread/46996
DH87RL Will Not Boot
/thread/47022 https://communities.intel.com/thread/47022
Silvia_L_Intel1
Arkiados,
This information has been provided at the following link:
