Intel® Desktop Boards
Peer-to-peer support only
11475 Discussions
DH87RL USB 3.0 back panel connectors
MGoes
I have installed a new DH87RL lately. Everything works fine except the back panel usb connectors: My external usb 3.0 hard drive does not connect with superspeed, although I connected it to the back panel connectors. Seems like the back panel ports are running usb 2.0 only:
Is this a known problem or a configuration issue?
Thanks in advance for any hints.
Michaelusb 3.0
Silvia_L_Intel1
djONz, for this kind of behavior I will recommend you to check if you are running the latest BIOS available for this motherboard.
This is the latest USB 3.0 driver https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22589&lang=eng&OSVersion=%0A%09%09%0...
If you connect the USB 3.0 hard drive on the ports located at the front of the board, which is the behavior?
Which is the AA# of your motherboard?
Silvia_L_Intel1
MGoes
Sylvia,
Problem solved. I didn't think of the most obvious. Shame on me...
Thanks a lot!
Michael
Silvia_L_Intel1
No problem Michael!! I'm really glad to know your system is working now.
