Intel® Desktop Boards
Peer-to-peer support only
11475 Discussions
DH87RL - fan control does not work
MKleu
Hi, there,
I've built a new system with above mentioned board. Most of the things are doing well, except the control for rear and front fan:
The CPU fan speed is around 557 rpm (with idle Windows desktop) - it will raise, if there's something to do for the cpu
The rear and front fan display switches between approx. 800 and 20.000 rpm - the fans itself turning silently at very low speed (even if there's cpu load)
The fans are connected with 3 pins.
Board Model: DH87RL
Board Version: AAG74240-403
BIOS-Version: RLH8710H.86A.0325.2014.0417.1800
Any ideas whats going wrong here?
Martin
Edit: For testing purposes, I've put an old 4-pin-fan in, and it works like a charm - maybe the front/rear fans have to have a 4-pin connector, too?
Silvia_L_Intel1
Hello Martin, I am sorry to hear that you are having this kind of problems on your motherboard.
The following article will give you information about this behavior, since it is totally expected when using a three wire fan connector.
The 4th pin is the one in charge of the fan control; therefore it is not working when using those fans on your chassis. http://www.intel.com/support/motherboards/desktop/sb/cs-012074.htm Desktop Boards — Three-wire and four-wire fan connectors
Silvia_L_Intel1
JBish3
New Contributor II
Hi Martin, you are facing this problem because you have 3 pin FAN SINK. Please note for fan control you must have 4 pin FANSINK. Because the 4 pin is responsible for carying the FAN speed. details given below
PinFour-wire fan support1Ground2+12 V3FAN_TACH4FAN_CONTROL
for resolving your issue buy a 4 pin FANSINK.
Thanks & regards,
Jitendra Bisht
MKleu
Hi, Jithendra,
I knew, the CPU fan is only supported if connected with 4 pins, but I thought the rear and front fan are supported if 3 or 4 pins.
Thanks anyway,
Martin
MKleu
Hi, Sylvia,
thanks for this very fast response - now, everything is clear. I've misinterpreted the 3pin/4pin option. I'd call it p.e.b.c.a.k. ;-)
Martin
