probably I have different expectations to the normal user but anyway.
I've got a DH87RL board connected to a Corsair Carbide 200R case which has a front panel connector for microphone and speakers.
As soon as I plug in the earphones into the front out the back panel speakers are turned off.
What I would like to have and what worked out of the box with my previous MSI board is a parallel output for both connectors.
Is that possible somehow?
Thanks for any hint,
Wolfgang
Wolfgang,
This is certainly possible. What OS are you running?
...Scott
I'm running Linux (with pulseaudio 4).
In pavucontrol both outputs are enabled as far as I can see. So you are saying that it is the software disabling the output when the earphones are plugged in?
I haven't had to do anything special with my other hardware though.
