Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
For the latest information on Intel’s response to the Log4j/Log4Shell vulnerability, please see Intel-SA-00646
11381 Discussions
DH87RL - no bios recover working
DHier
Hi Community
Just received a DH87RL. I did build a System mSATA SSD; system did boot/BIOS splash visible.
Install pve Linux 2.6 on mSata with KVM work fine for me a few days. (perfect Motherboard)
But system restarts after shutdown every Time. Only pressing Powerbutton while BIOS splash visible stops rebooting.
I start update BIOS (http://www.intel.com/support/motherboards/desktop/sb/cs-030144.htm http://www.intel.com/support/motherboards/desktop/sb/cs-030144.htm) to latest BIOS, RL0324.bio with 4GB USB-Stick.
While select the .BIO file and press Enter, short Flash on HDMI-Screen and System is down.
System did not boot again, no BIOS/BIOS splash visible over HDMI or DVI.
  1. I follow Instructions for Recovery BIOS Update (http://www.intel.com/support/motherboards/desktop/sb/cs-023360.htm http://www.intel.com/support/motherboards/desktop/sb/cs-023360.htm) with USB or CD-ROM (Point 7. not visible for my).
  2. Maximal 4 Beeps on pressing PowerButton at Power on is working and Shutdown the System. Pressing PowerButton while waiting for 3 Beeps but no Bootscreen visible. Nothing happens on pressing F2, F9...
No Error Beep Codes on Systemstart.
No led flashing on USB-Keybord.
System is not Booting over Bootable USB-Stick, mSSD-HD, SATA-HD, SATA-BD or pxe Netboot-Server.
Are there any other solutions to update/recover Bios?
best regads
Dirk
Jose_H_Intel1
Hi Dirk, you may try removing the power and CMOS battery for half hour and then try a BIOS recovery. However, if you do not get the expected beep codes (without RAM) I believe the chances are not good.
May I ask what the previous BIOS version was? It is highly recommended to update the BIOS incrementally.
