Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
DH87RL with 4 modules 8GB?
MMALL3
Since the memory system supports up to 32GB can I use 4 modules 8Gb 1600 MHz?
Silvia_L_Intel1
Aquila44, you will be able to find all the supported memory configurations on the following link.
http://www.intel.com/support/motherboards/desktop/db-dh87rl/sb/CS-034215.htm http://www.intel.com/support/motherboards/desktop/db-dh87rl/sb/CS-034215.htm
Just in case, remember that low profile memory is not supported by this motherboard.
MMALL3
Thanks Sylvia but I have already read the configurations you mentioned and my doubt still remains.
For example: •32 GB maximum total system memory (with 4 GB memory technology).
The answer that I need is simple YES or NO.
Can I use 4 modules 8Gb 1600 MHz?
Sorry about my bad English
Silvia_L_Intel1
Yes you can use 4 sticks of 8GB 1600MHz of RAM; however it has to be double-sided with 4Gbit SDRAM density.
MMALL3
Could you explain "double-sided with 4Gbit SDRAM density."?
Silvia_L_Intel1
It is required that the memory sticks are built based on "Double-sided, 4Gbit SDRAM density"
This means, that the memory sticks have to contain a chip distribution in the two stick sides and each chip has to be made based on 4Gbit density.
For more details about memory construction and specifications on the memory please contact the memory manufacturer and they can give more information about that.
MMALL3
Understood.
Thank you very much.
